Windows rattle like hell, Help!!
Old Oct 13, 2003 | 10:23 AM
95TEGGY's Avatar
95TEGGY
Default Windows rattle like hell, Help!!
Hi guys, i have power windows and i have a little problem here. Whenever i close the doors, it seems like my windows are going to break because of such a loud hitting impact noise, and whenever my base hits, it rattles in a very annoying way, its like there is no patting holiding the glass in place. Can you guys help me out cause i have no idea what to do. I opened the door panel, but i still couldnt reach the glass because there is another metal piece covering the glass. The actual window is between two metal pieces so by opening the door panel i still couldnt see anything. If you guys have same problem or know how to fix it, please hit me up. Thanks
Old Oct 15, 2003 | 05:07 PM
SRD_DC2's Avatar
SRD_DC2
I have the same exact problem, and so do all my freinds with 94-95 integras!! I also removed the door panel and there isn't much room to work with, and it is hard to see what could be causing the problem. Crap is annoying!! Also seems as if alot of integras have this squeaking/rattling noise that comes from the rear of the car too. Anyways, any help would be nice...can get real annoying
Old Oct 15, 2003 | 05:26 PM
tas31804's Avatar
tas31804
hey my 92 teg does both it rattles and squeaks alot i tried taking off the door panel and tryin to tighten anything that lookd loose but it didnt seem to help really
Old Oct 20, 2003 | 11:21 AM
uclaccord's Avatar
uclaccord
i got the same prob too on my accord...i read that the prob is common and that there are rubber guiding tracks inside the panel that fall off...so they don't guide the window and they don't keep everything tight...i've been too lazy to go inside my door and check...ppl have a crazy hard time getting the tracks to actually stay there...like...they fix it but after awhile it busts again
Old Oct 20, 2003 | 12:42 PM
95TEGGY's Avatar
95TEGGY
ya well after you take off the door panel, you still gotta remove that metal piece that has the plastic thing stuck on it. And all the glass and power motor and stuff is all in there. Its been raining like a motha****a in here and i dont have a damn garage and its gets way too dark after i get off work so i havent really had time to do much.
Old Sep 28, 2005 | 03:29 PM
NAUGHTY69's Avatar
NAUGHTY69
Default My Intergra Rattles And Scweeks In The Back Too
MY INTERGRA RATTLES AND SCWEEKS IN THE BACK TOO
I DONT KNOW WHAT IT IS BUT IF ANY ONE DOES PLEASE LET ME KNOW..ESPECIALLY WHEN I STEP ON THE BRAKES BUT ITS NOT THE BRAKES..PLEASE HELP!!!
Old Sep 30, 2005 | 05:58 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
for 94 accord click here
or just visit www.hondaautomotiveparts.com and put in your year and model and tm type, and click on part "Front door window"
good luck. replacking the rubber might help? i don't know, the best i can do as i have never had these problems.
i could probably fix the problem myself if i was working on it, but since i am not, the best i can do.
hoyoung02
Old Oct 11, 2005 | 08:23 PM
velondra's Avatar
velondra
i.defecate.where.you.drea
what i would do, and am going to do with my civic, is get some foam for the internal rattling in the door, cause when i turn my volume up and my system isnt even installed i have the same problem. if you turn your bass up and find every little place tha rattles, work from one to the next.. tightening each thing you can. although you cant use the foam in places like the rods inside the door otherwise things wont work like they are suppose to. just a suggestion from a rookie.
-v
Old Aug 17, 2008 | 05:07 PM
arvinny's Avatar
arvinny
I have a 96 integra with the same rattle problem( driver's side ). I took the door panel off and found a weather strip inside door panel. I pulled it out, cleaned it, used a strong adhesive( 3m ), replaced the weather strip in the window glass run channel(left channel-closer to the door handle), rolled the window down and let dry for a couple hours. now the window doesn't rattle. so thats the problem with most tegs I guess. check yours and look for that fallen weather stip! good luck!
Old Aug 18, 2008 | 07:08 AM
lkailburn's Avatar
lkailburn
college kid
nice! yeah i have this same problem - 97 civic. it's so hard to figure out where exactly the rattle is comming from so i gave up but maybe i'll get back in there and see if i can find what you guys have suggested
-Luke
