civic Headlight highs only work on one side
Old Oct 10, 2003 | 09:22 AM
jizzmpeats1422's Avatar
jizzmpeats1422
Default civic Headlight highs only work on one side
When i turn on my headlights, they work fine. When i use the highs, only one side comes on. Why is this? I have checked the fuses for the highs and they seem to come out fine.........
Old Oct 10, 2003 | 10:35 AM
96GreenCivic's Avatar
96GreenCivic
is the filament on the high burned out...... it could be as ez as that.
Old Oct 10, 2003 | 11:48 AM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
yea you might just need a new bulb,...but if your gonna change one,..might as well go ahead and change the other one as well,..but yea since you said you checked the fuses,..change the bulbs
Old Oct 11, 2003 | 08:43 AM
jizzmpeats1422
Each side only uses one bulb and I have checked those. i had originally tried putting the stock bulbs back in and they work fine except for that one bright. So, now i'm starting to think it's the wiring or something else.
Anyone ever heard of the blinker switch having a short? I use it to activate my highs by pulling back on it. I talked to a guy who said it could be in that switch that there may be a prob....
Old Oct 11, 2003 | 09:04 PM
YeaItsAFourDoor's Avatar
YeaItsAFourDoor
..::-Free your mind-::..
Buy new bulbs, put those in, if there still is a problem check the ground wire...check the wires...
Old Oct 17, 2003 | 01:25 PM
AccoRdvtecEX's Avatar
AccoRdvtecEX
yep... i guess that could be the problem. Im having the same problem w/ my cord's angel aye projectors. The high beam projector is dead on one side and my regular driving beam's output is pretty bad. I figure getting new bulbs... thinkin of PIAA's... what ya think? are they the best?
Old Oct 25, 2003 | 01:00 PM
jizzmpeats1422
As it turns out, the filament on the high on just the driver side was burned out. Even though i had already checked them, the bulb stilled proved to have bad filament on the high. I guess i checked the bulbs too soon after i cleaned my engine bay.:thumbup:
Old Dec 9, 2003 | 05:28 PM
jlude92's Avatar
jlude92
i'd check the bulbs, then the wires....if that dont work i'd purchase some new bulbs..
Old Dec 9, 2003 | 07:51 PM
habitatsk8r392's Avatar
habitatsk8r392
Certified Ricer
they are pretty good....but whatever u do get, DON'T GET SYLVANIA SILVERSTARS. THEY SUCK
seriously i had them and they were no whiter than my stock bulbs...worthless
