replace TPS?? how
Old Oct 8, 2003 | 01:15 PM
menappi's Avatar
menappi
Default replace TPS?? how
how do i replace my TPS on my ZC..i dont see where it can come off..and can i use my SI one?
Old Oct 8, 2003 | 06:22 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Its not supposed to be removable. However it is held on by 2 rivets as some people call them, yet I have a feeling they are really more like shear bolts. But anyway if you cut them with a dremel or something to make a slot you can unscrew them out and remove the TPS. Than install a new one. You will need to use a volt meter to correctly set the new TPS though as it gets messed up once you take it off.
Old Oct 9, 2003 | 07:13 AM
jlicrx's Avatar
jlicrx
much easier just to swap the Si throttle body onto your engine - without sophisticated equipment, you will never get the TPS set right - most voltmeters are not sensitive enough to get it right on
