please help me w/ codes
Old Sep 9, 2003 | 11:12 PM
2manyticket$'s Avatar
2manyticket$
Default please help me w/ codes
im a new member and new owner. i was wondering if anyone knows the codes for 90 crx dx/ex? my ckeck engine light came on, when i checked it the red light blinked once then a pause and then 16 blinks.
Any help would very much be appreciated. Thank you
-Tristan
Old Sep 9, 2003 | 11:49 PM
Redlinerz's Avatar
Redlinerz
When it blinked once it is just when it turns on after that is when you start counting...code 16 has to do with fuel injection system..make sure all the plugs are in all they way and get you fuel system cleaned out. The rest of the codes for your car is as follows
1- oxgyen sensor
4- crank shaft position sensor
5- MAP sensor
6- Engine coolant sensor
7- Throttle position sensor
8- TDC sensor
9- CYP sensor
10- Intake air temp. sensor
12- EGR lift sensor
13- BARO sensor
14- Idle air control sensor
15- Ignition output signal
16 - fuel injection system
17- Vehicle speed sensor
20- Electrical load dector
30- Automatic transmission signal A
31- Automatic transmission signal B
41- Primary oxgyen sensor- heater
43- Fuel supply system
that is the codes..some were skipped over because they did not concern the 90 civic...Hope the list helps you in the future..and my advice to any new civic owner...get yourself a helms
