What would u do?
Old Aug 18, 2003 | 10:11 PM
Africanqueen's Avatar
Africanqueen
Default What would u do?
if you had 10 grand to spend on an engine swap, what would u purchase?
I have a 88 rex that it will be going into and i need some help ya'll. This will eventually be a drag car. It is a bone stock rex with i/e that's it. It has a rebuilt d16a6. i hit 15.9 at california speedway(dont know if that's good or not) a couple weekends ago.
This swap will be going down in about 6 months. So every post is very appreciated. I need some hardcore help here.
I dont know if it's better to boost or go naturally aspirated.
Here is the list of things that i would do. feel free to put down what u would do.
1. LS/Vtec NA
2. LS/Vtec Turbo
3. B18c5 NA
4. B20 VTEC Turbo
5. B20 VTEC NA
6. B18c1 Turbo
7. B16 Turbo
i dont know, what would u do. Post ur setups and pics if u want. Thankz in advance guys
Old Aug 18, 2003 | 10:47 PM
Snoopy's Avatar
Snoopy
been there done that
built b20 turbo :rick:
Old Aug 19, 2003 | 12:50 AM
malfuncion's Avatar
malfuncion
Z20 H8R
http://www.dh-racing.com
www.gude.com
www.exospeed.com
those are two places that do some serious work. top one has any honda motor fully decked out and waiting to be dropped. depends on how much you want to spend. you will definately get your money's worth. now on the second one its mainly just head work. make sure yo have a pretty fresh motor or at least a semi built one though, i learned the hard way that bumpin up your compression will lead to bad thing ::cough::spun rod bearing::cough::
oh if you want to see what you get view my post "this is my rex". las pic is of the gude head package. port n polished head, 5 angle valve job, cams (in the white boxes), throttle body, and manifold, all of which are match ported. an instant 50 hp bolt on or so they say. i havent got to reap the benifits cause like i said i spun my bearing so umm yeah my car is being rebuilt right now. but at the same time its a good thing for i shall dessimate all once its all said and done and broke in.
oh and btw if you're talking bout a shop doing it all for you the b series turbo setups, more than 10 G's. First gotta buy motor, then gotta build motor, then buy turbo. better have more like 15 and even then you might even be scrapin by. i was looking at like around 7 or 8 to have a built motor and turbo setup. that was to push around 10 psi. its like 8 or 9 to push more. but then again thats a shop and if you can do it yourself then your looking at around 10g's for everything.
