sway bars...
Old Jun 26, 2003 | 04:20 PM
doIhaveBDIs's Avatar
doIhaveBDIs
Banned
Default sway bars...
i just got them!!!
the front looks easy as shit...
the rear looks a little confusing....
if u got some tips for me that be ****ing sweet!
btw wheels will be here July 1st with my neuspeed strut bar!!!
Old Jun 26, 2003 | 04:52 PM
matt j's Avatar
matt j
midwest corn killer
make sure when you are putting them on that the suspension is under load i.e. the car on the ground ( you need a lift or drive the car up on blocks high enough for you to get under it
Old Jun 27, 2003 | 07:32 AM
jung4g's Avatar
jung4g
Asianalize your car
NOPE, I did my front one last week, you just can have only 1 side lifted, if they are both off the ground you're fine.
For the rear, I went to put mine on (stock Si rear) and I couldn't use it do to the placement of my exhaust (shitt custom). But those funky standoffs for the bushings that you should have bolt right up, and unless you have Si rear control arms, you'll need to drill a hole through your control arms to attach the sway bar...'
Good luck
Jung
