ECU location
under the carpet of the passenger side of ur car, where the passengers feet are normally at, if u pull up ur carpet, you will see a metal plate with 4 bolts. remove those bolts and u'll see the computer that runs ur car or ur ecu, tada....hope that helps. good luck
