Clutch Problem
Old May 20, 2003 | 08:40 AM
CRXDOHCVTEC's Avatar
CRXDOHCVTEC
Default Clutch Problem
I bought a 91 Integra Clutch For my b16a1.(The Guy From HondaMotorsOnline told me to get a 91 integra) I have put the CLutch in Already and the Car Doesnt Move when i try to Drive it...
do anyone know whats wrong?
What Kind Of Clutch Alinement Tool Kit do i Use to Aline the clutch up with?
How would you or how can you tell if the Clutch Wasn't Aline Right?
PLease give me some kind of information........Thanks.
Old May 20, 2003 | 08:55 AM
SoSoDef24's Avatar
SoSoDef24
that sounds weird. maybe the clutch cable is screwed up???
Old May 20, 2003 | 09:36 AM
CRXDOHCVTEC
The Car can Start But it Can't Move... It can Rev But it wont Move.? can it be that the Alinement was wrong?
Old May 20, 2003 | 09:58 AM
jaje's Avatar
jaje
HC Racer H5
when you push in the clutch do you get smooth action with normal resitance or does it push in really easy?
i'm thinking it could be the cable or the throwout bearing
as for the clutch ALIGNment (not aline) tool i use a universal set you can get at the autostore...but your kit should have come with a plastic unit
Old May 20, 2003 | 10:23 AM
crxb16er's Avatar
crxb16er
yah check ur clutch cable make sure that it's actually pulling and releasing the clutch properly, if so then something wasnt installed correctly, and umm hopefully someone else will know if thats the clutch ur supposed to have. alignment doesnt really affect ur clutch working just ti getting worn out, if its not centered correctly it will wear out prematurely
Old May 21, 2003 | 11:13 AM
CRXDOHCVTEC
ok the clutch Cable is tight...?
Old May 21, 2003 | 11:23 AM
CRXDOHCVTEC
when i push in the clutch it feels normal........
Old May 21, 2003 | 11:55 AM
crxb16er's Avatar
crxb16er
possibly throw out bearing problem, if the clutch isnt engaging at all, and ur sure the shift linkage is installed the same as it was b4 and its in gear? something is probably wrong other than ur clutch if its all put together correctly, ill pull out my helms later tonight and see what other issues it may be and ill give u a complete run down of the install and hopefully figure out whats wrong with it
Old May 21, 2003 | 02:07 PM
CRXDOHCVTEC
thanx!
Old May 22, 2003 | 01:48 PM
CRXDOHCVTEC
how do you put in the throw out bearing?
