possible rotor problem. help!!
Old Mar 30, 2003 | 05:51 PM
tecKNoW's Avatar
tecKNoW
Default possible rotor problem. help!!
Whenever im at high speeds and i break my steering wheel shakes, also my passanger side front tire makes weird noises like its rubbing up against something when i drive at normal speeds and high speeds as well. What might be the problem?
Old Mar 30, 2003 | 07:16 PM
excitid's Avatar
excitid
Possibly the wheel bearings are worn out I had that type of noise and thats what I changed to fix it. That could affect the braking too or maybe your rotors are warped. Check your tie-rods and bushings also.
Old Mar 31, 2003 | 07:53 PM
joshwhe's Avatar
joshwhe
whats your tire wear look like????
Old Mar 31, 2003 | 09:45 PM
tecKNoW's Avatar
tecKNoW
all my tires are in good condition.
Old Apr 1, 2003 | 03:01 AM
excitid's Avatar
excitid
Jack up the car and grab the top and bottom of your tire and see if it you can move it, also you can spin the tire and see if it has alot of resistance and you will probably hear the noise also. I would also check the brakes worn rotors and pads could cause you to have noises also.
Old Apr 1, 2003 | 07:41 AM
tecKNoW's Avatar
tecKNoW
Default rotors
thanks for the tips excitid. I'll try that and see what i come up with
tecKNoW's Avatar
tecKNoW
Default rotors
Old Apr 1, 2003 | 07:42 AM
tecKNoW's Avatar
tecKNoW
Thanx for the tips.I'll try them and see what i come up with.
Old Apr 3, 2003 | 08:19 AM
excitid's Avatar
excitid
did you find out what the problem is.
