Look what fell into my lap
HC Racer H5
for $50 i got a td05h 14b turbo off a 1g eclipse including a new set of gaskets...it has 100k on it but looks in decent shape...i'm gonna rebuild it and install new bearings, etc.
this will be a fun future d16a6 project as i already have an hf manifold lying around from a previous swap
here's some pics
old hf header
wonder if these are bad things with it...
turbine housing cracks (they are small and don't look threatening...i haven't polished it yet to see the full extent)
here's some pics
old hf header
90 accord h22a
Re: Look what fell into my lap
here's some pics
old hf header
here's some pics
old hf header
good lucky buddy looks kinda old and crusty but hopefully with some work and not too much $$$ you can make something nice out of it, and if for the 50$ u can do it you'll save alot over buying a new one for 2k, but like i said good luck to you
HC Racer H5
it's in good shape...minimal shaft play...but for $100 i'm gonna get the rebuild kit and port the turbo
it even came with new gaskets and a 3 month old o2 sensor!
it was just the small cracks that worried me...but after posting on some dsm sites those are quite common and do little to reduce its lifetime (almost all of them crack like that after a while...this one has 100k miles on it)
90 accord h22a
HC Racer H5
Originally posted by fizzbob7
you should be able to get a rebuild kit for $75 from majestic turbo.....if you don't get the shaft balanced during the rebuild, then don't expect it to last long.....it will wear the bearings out sooner.....you can get it balanced by majestic for like $40 last time i checked.....the rebuild kit even comes with a video on how to do it.....easy after you've done it a couple of times, but if it's your first, then take your time and be careful....easy to mess things up
