how to remove rotor??
Old Mar 24, 2003 | 09:31 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default how to remove rotor??
how do i go about in removing the rotor... i know there is one hugh bolt that locks it in place. so which tools do i need to remove it with ease???
Old Mar 24, 2003 | 11:29 AM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
You mean the Brake Rotor (I assume not Distributor Rotor). For the Brake rotor take off the wheel and unbolt the brake caliper. There are 2 screws holding on the rotor, use an impact driver to remove them, DON'T USE A SCREWDRIVER, you will strip them and make it a bitch to get them out again. The huge nut you speak of is the axel nut, it holds on the axel, not the rotor.
Old Mar 25, 2003 | 09:43 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
cool... thanks!:thumbup:
Old Mar 25, 2003 | 11:23 AM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
If it has been on there for any amount of time it might take a few whacks from a hammer to unseat it. This is after you remove the caliper and said mounting screws.
Old Mar 25, 2003 | 08:25 PM
Kai's Avatar
Kai
Rotorphile.
:werd:
My new air compressor got its first use today on my front brake rotors. Use anything less then air tools and you'll be crying over stripped screws. Make good friends with someone with an air compressor if you don't have one already. It'll be worth it when you see those otherwise impossible-to-remove screws come flying out of the hub
Old Mar 26, 2003 | 05:23 AM
crxrocks's Avatar
crxrocks
Originally posted by Kai
:werd:
Huh? I have never once needed to use my compessor for doing brake work. Just go to your local Sears and get an impact driver. Basically, it is just a screw driver that you smack with a hammer. When you hit it with a hammer it turns the screw, understand? Don't worry, you don't need to use air tools.
Chris
Old Mar 26, 2003 | 06:19 AM
FourthGenHatch
Chris
Werd. Impact Driver is not an Impact Wrench (Air Tool). It's basically a fat Screwdriver that when you hit it it turns 15* and puts out like 200ft-lbs of torque but when you hit it it also keeps it from coming out and stripping the screws.
Old Mar 26, 2003 | 10:55 AM
Kai's Avatar
Kai
Rotorphile.
Oh yeah, one of those thingies... I forgot about them.h:
I bet my impact wrench is still faster though
