junkyard mods
Old Feb 5, 2003 | 10:01 AM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Originally posted by crxrocks
Not true in this case. The LS tb will fit on the d16 intake manifold. Your best bet is to just buy one and see what needs to be done. There will be some modification required, but since I haven't done it, I can't tell you word for word.
Chris
If it bolts right up how come not everyone does it to have a huge throttle body on their D?
Old Feb 5, 2003 | 10:16 AM
crxrocks's Avatar
crxrocks
You didn't read my post very well. I said there will need to be some modification, but it is pretty minimal.
Chris
Old Feb 5, 2003 | 10:52 AM
RiceBoysDream's Avatar
RiceBoysDream
i have another question u know the crx sir over japan brings a b16a will the mounts that hold that motor in fit in our cars if you use them? i mean i think they would bolt right up to any bseries motor correct? im just thinking of a way around buying aftermarket motor mounts for a b series swap.
Old Feb 5, 2003 | 10:03 PM
Kai's Avatar
Kai
Rotorphile.
Sure, assuming you have an entire SiR front clip, a welding machine, fabrication skills, and a LOT of free time on your hands. In short, no. Hate to say it, but you have to use aftermarket mounts for the quickest, easiest, and cheapest installation.
Old Mar 1, 2003 | 01:31 PM
joshwhe's Avatar
joshwhe
no mods to on a ls tb to a 92+ d series mani
Old Mar 1, 2003 | 01:58 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If you're using the b16a from a crx sir, then it will bolt right in, but you will need the mounts that come with that engine.
Old Mar 2, 2003 | 08:48 PM
Kai's Avatar
Kai
Rotorphile.
Sorry, but that's not right. The J-spec CRX SiR used different mounting points in the engine bay itself, thus creating the market for swap mount kits. A B-series engine will not bolt into any US market pre-92 Civic/CRX body without an aftermarket or custom mount kit, or otherwise modifying the actual chassis mount points.
