new thottle problem
Old Jan 2, 2003 | 07:53 AM
blue ice's Avatar
blue ice
Default new thottle problem
i have a 88 civic dx (bone stock).. when i start it ...it will run for about 30seconds and die.. i have just changed the thottle body but did not replace the gaskets... i will it kill the motor or just make it run like crap??? help help ... i am going to drive it off a bridge soon!!!!!!!
Old Jan 2, 2003 | 08:17 AM
excitid's Avatar
excitid
what was wrong with it that made you have to change it. ARe you throwing any codes. I guess my next suggestion should be to just go over your work again check all your connections and plugs and etc.
Old Jan 2, 2003 | 08:53 AM
WhiteRice's Avatar
WhiteRice
Check your dizzy, make sure it's in tact. Check your ignitor, and probably your main relay too.
Old Jan 2, 2003 | 09:22 AM
blue ice's Avatar
blue ice
it WAS giving me a tps code so i changed it..it was still act up so i took it to a shop they said bad thottle body so i changed that and it is still f up.. it is not throwing a code but it will only idle for 30 seconds... i am getting spark ... i have checked over everything for 3 weeks...
Old Jan 2, 2003 | 11:08 AM
excitid's Avatar
excitid
what happens if you hold the gas pedal down. Does it start up fine. When its idling for the 30 seconds does it idle fine or is it rough and sputtering. Have you checked your fuel system.
Old Jan 2, 2003 | 12:45 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
What's with everyone jumping on the main relay thing lately. Blame it on the main relay! A main relay will normally only keep the car from starting, and only in hot conditions. Other than that, a relay is just a set of switches, so the car with run, or not run. That's it.
Back on topic, if the gasket has any leaks, it can definitely make the car idle higher. Check the idle adjust, and one other thing to try would be to take your tps off and throw it on the old throttle body...
Old Jan 2, 2003 | 06:42 PM
WhiteRice's Avatar
WhiteRice
I think it's kind of like when someone first buys a bone stock car, and they ask what should I do. The COMMON answer is intake, header, and exhaust right? Well, when there is a car that is having trouble starting or staying running, the dizzy and the main relay are COMMON problem areas.
