Water on capet on passenger side
ok so its rainy as hell here in WA right now...and it just started happening...i get a good amt of water on my passenger side carpet (front only) what you think the problem is? my floor pans are fine...is there a drain plug down there that might have fallen out or somthing?
How does the water collect...is it from just sitting in the rain or does it collect when driving the car or both?...can you investigate where the leak may come from (i.e. ceiling, etc...you could pull up the floor/carpet to see if you can find any holes, etc.)
wooooo woooooooooo
it's your ac condensor tube. It's either clogged or has come out of the hole that goes through the firewall. Happens all the time on Hondas. Look up under the dash on that side, and there is a hose about 1/2 inch in diameter. That should be the one to look at.
Originally posted by GreenMachineREX
mine is in the rear, on my crx....? could this be from my rear pillar things that leak?
