Code 9
Old Sep 7, 2008 | 05:25 PM
Omie's Avatar
Omie
ew n!gg@ u g@y
Default Code 9
9* Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98** 86-98 97-98 85-91 93-97 95-98 85-98
CYP Sensor (Cylinder)
defective circuit or unplugged / defective sensor
* not a valid code for any throttle body injection
any one have any idea how to get rid of this or a diagram
the car is a 90 crx si with a dohc zc with a t3/t4 turbo
i'm asking for a friend and i figure you guys might have an answer
Old Sep 8, 2008 | 06:05 AM
jlicrx's Avatar
jlicrx
code 9 on the DOHC ZC usually means that your camshaft timing is not correct or the Cylinder Sensor on the end of the exhaust camshaft is not wired up right
Old Sep 8, 2008 | 07:42 AM
Omie's Avatar
Omie
ew n!gg@ u g@y
thats what i was thinking but we found on the hondata software that the fuel was cut by -20% so that might be the problem. if not do you have/ or know where i can get a diagram from?
Old Sep 8, 2008 | 09:24 AM
jlicrx's Avatar
jlicrx
you shouldn't need a diagram - the blue/green wire that originally went to the Si distributor should go to the blue/green wire at the green connector on the Cylinder sensor - the blue/yellow wire that originally went to the Si distributor should go to the blue/yellow wire at the green connector on the Cylinder Sensor - my bet is that camshaft timing is not correct
Old Sep 9, 2008 | 04:20 AM
Omie's Avatar
Omie
ew n!gg@ u g@y
ok i'll check that today with my friend
