Engine Help
Old Apr 23, 2008 | 10:20 AM
hondaluver12's Avatar
hondaluver12
Default Engine Help
I bought a 1990 civic, with a 1.6 non V-tec(ZC). With a two point injection system. It has good spark, compression, the timing is dead on, and its getting fuel. If i play around with it i can get it to run. When its running it will act fine(rev up, and pur like a cat....) it throws the code 7 tho. It will run till the engine gets up to temp. then it dies, and it wont start after that. i have to let it cool down, but still its a bear to get it started. and then its the same story. so if anyone can help please do....
Old Apr 23, 2008 | 06:12 PM
hitman619's Avatar
hitman619
SDSU Basketball
Sounds like your (Throttle Position Sensor)
looks like you can adjust it
here's a site hope it helps
http://www.automedia.com/Throttle_Po...cr20040701ts/3
