Cutting out
Old Oct 28, 2002 | 08:04 PM
HIFISI's Avatar
HIFISI
Default Cutting out
Hi my 86 Si civic ZC engine is cutting out between 4600-5000rpm. It is only doing this in first gear. I have new spark plugs, new dist cap and new ignition leads. the previous owner informed me that the ecu was replaced. The ecu is a pg7-033. i think this is a integra ecu. I am getting a code 1 fault code as well which is the oxygen sensor. Has anyone got any idea what may be causing it to cut out?
Old Oct 28, 2002 | 08:43 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
check that cat! the honeycomb is proly failing
Old Oct 28, 2002 | 09:29 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Sounds like you're kicking the ECU into open loop mode, usually happens when the TPS is at or above like 73% I forget the exact number. When in open loop it tries to read a voltage off the oxygen sensor, and if you're throwing a code for the oxygen sensor then that's probably what's causing the problem.
Old Oct 28, 2002 | 10:50 PM
HIFISI's Avatar
HIFISI
ummm what if i took the cat out?
im in new zealand and we have no emision controls so having no cat is legal
Old Oct 28, 2002 | 10:52 PM
HIFISI's Avatar
HIFISI
thanks fat booty i am going to get that oxygen sensor replaced.
