Short SHifter installation
Old Oct 6, 2002 | 06:41 PM
Creep's Avatar
Creep
Default Short SHifter installation
I want to install a short shifter on my 91 HB. Is it a better Idea to reamove the linkage from the car, or can I do it while it's on the vehicle?
I'm sorta going by the instructions on bseries.net, is it easier on
our cars?
Old Oct 7, 2002 | 03:08 AM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Its really easy, and no don't take the linkage off...
1. Jack up car.
2. Go under and undo the bolt for the shifter linkage at the bottom of the shifter, move the linkage out of the way.
3. Undo the bolts for the bracket that holds the shifter in place.
4. Pull down shifter and replace with new one, grease where it says to.
5. Put the bracket back in
6. Bolt the shifter to the linkage
7. Drop down car
And I would recommend upgrading to new Polyurethane bushings while you are at it. The rectangular bushing goes on the bracket (you will see it) and the other donut bushing goes where the torque rod (part of the linkage that stabilizes it) connects to the tranny.
Old Oct 7, 2002 | 04:42 PM
Creep's Avatar
Creep
Sweet...
You know your $hit... Thanks.
Old Oct 7, 2002 | 10:31 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
Jack stands are a good idea. Or ramps.
