Fuel system ISSUES
Old Feb 7, 2007 | 08:33 AM
theleprechaun's Avatar
theleprechaun
Default Fuel system ISSUES
Okay just did an engine swap and now I need to solve a fuel issue.
I'm fairly positive that I'm not getting fuel past the injectors in my 90 CRX-si.
I have fuel at the bleed bolt and fuel at the rail. I replaced the main relay and still no luck so I can only assume tht I have 16 year old clogged injectors, what's the cheapest way to solve this issue? Can I just buy a new manifold with injectors and rail, or is that outragously expensive? Or are the injectors easy enough to change that its better to just replace them, I don't wanna screw anything up.
Old Feb 10, 2007 | 02:45 PM
m735is's Avatar
m735is
Have you pulled the plugs to see if you're getting fuel into ANY of the cylinders? I wouldn't think they would all clog at once. Are the injectors firing?
Is your fuel pressure regulator good?
Old Feb 10, 2007 | 04:38 PM
Snoopy's Avatar
Snoopy
been there done that
if the injectors are clogged, send them to www.rceng.com to be cleaned and flow tested
