What motor should i use?
Old Nov 11, 2006 | 06:51 PM
Black_B18C1's Avatar
Black_B18C1
Default What motor should i use?
I have a 91 hatch with a B16A and 92 ls trans. The tranny is about to puke. I called gear speed and for carbon coated syncros,new seals and bearings $1600 or $2250 with Quaife diff. I would like to go through the motor and get 200 whp. Its about $2500. Or should i go with a B18C5. I'm afraid of getting a shitty tranny with the B18C5. Any opinions would be appreciated. Thanks
Old Nov 11, 2006 | 07:06 PM
Snoopy's Avatar
Snoopy
been there done that
buy a b18c1 block, slap the b16 head on there, and go from there. you can find a used cable b16 tranny for pretty cheap too.
Old Nov 11, 2006 | 07:17 PM
b18c1_hatch's Avatar
b18c1_hatch
Get a type r and do cable to hydro conversion
Old Nov 11, 2006 | 11:53 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Buy a LS block, and a YS1 tranny.
You can get them for under 800$ shipped.
Old Nov 12, 2006 | 04:24 PM
18crx's Avatar
18crx
stock booster
intersting i make a little over 200 at the wheels and my tranny is golden its a ls. with a welded diff. guy i race with has a eg thats at 314 and same ls tranny and clutch no problems, i say ls tranny. well if you get a tranny with the b18c hell go with it. ans for the motor, is it going to stay NA then bigger is always better as in digger displacement.
Old Nov 13, 2006 | 03:54 PM
Mugenfreak's Avatar
Mugenfreak
Boost Hungry!
bigger is always better for BIGGER hp...displacement ultimately is the limiting factor to making power
Old Nov 14, 2006 | 05:52 PM
Black_B18C1
Thanks for the info guys
Old Nov 14, 2006 | 08:14 PM
sherwood's Avatar
sherwood
I missed Sean
snoopy, you didn't.....
in stock form the b18c1 p72 head will out-perform the b16's PR3
the only pr3 head to oust a p72 head is the one found on the type-r, and thats just because it's ported like whoa.
i suggest you buy a b18c1-- put in some high comp pistons with a good port job... you could bore it out, but for price reasons i'd suggest just going with the current bore.
use some low/high rpm range cams and use the b18's tranny-- you can then tune it and you should come out with about 190+whp on 93, but be warned that the number may be hard to hit with the 1.8L displacement.
Old Nov 14, 2006 | 08:26 PM
Snoopy's Avatar
Snoopy
he already has a b16. it's cheaper to just get a b18c block and slap the b16 head on there. you dont have to remind me about the different heads.
Old Nov 14, 2006 | 09:32 PM
sherwood's Avatar
sherwood
I missed Sean
i thought you told him to buy the c1, yes you are correct.
though for his application it would probably be better going with a ported p72 head to get the most out of the engine regardless.
if you were going to suggest a block to make around 200 horse it must be said that it's probably even cheaper to go ls/vtec, because he'll have to contend with replacing the pistons for compression and rod bolts for the high revs regardless... the only thing he'd have to worry about is getting the oil to the head, which is easy enough compared to what else is being done...
