dohc zc
Old Jul 18, 2006 | 12:20 AM
krongnome24's Avatar
krongnome24
Default dohc zc
Right now i have a sohc zc motor in my 1991 civic si and its not cutting it. I was wondering if swapping it for a dohc zc motor would be worth my money , because I've heard some good things about the dohc because of the money saved and the ease of installation. I'm on a low budget so i need a good swap for my money; any ideas or input?
Old Jul 18, 2006 | 11:38 AM
Kai's Avatar
Kai
Rotorphile.
DO you have a stock D16A6 or a real SOHC ZC?
Old Jul 18, 2006 | 03:44 PM
krongnome24
its the sohc zc that is pretty much equal to the d16a6, but it just says zc on it.
also, couldnt i use my zc tranny with the dohc zc?
Old Jul 19, 2006 | 08:13 AM
jlicrx's Avatar
jlicrx
on a low budget, staying with the D-series engine will be the least expensive - of all the D-series engines, the DOHC ZC will outperform any of the SOHC engines and it will be the easiest to install in your car - will bolt right up to your transmission and mounts - use the engine harness from your SOHC ZC and you will need to make a minor wiring change at the distributor
Old Jul 19, 2006 | 03:01 PM
mistacee's Avatar
mistacee
Zc powered ED9
Go with the DOHC, best bang for the buck, especially on a low budget and it is easy to install.
I have have had both the SOHC and DOHC, prefer the DOHC.
Old Jul 19, 2006 | 11:25 PM
krongnome24
sounds good thanks alot
Old Jul 22, 2006 | 04:58 AM
HONDA_driven's Avatar
HONDA_driven
got vtec?
Also, almost any B series bolt-on will work with the DOHC ZC. Even Jackson Racing makes a Charger set-up specifically for your ZC swap. Kool huh?
Old Jul 23, 2006 | 08:39 AM
jlicrx's Avatar
jlicrx
that would be D-series - B-series parts (except for cam gears) will not fit on the DOHC ZC
