bad starter?
Old Jul 5, 2006 | 11:30 PM
krongnome24's Avatar
krongnome24
Default bad starter?
my 91 civic doesnt start. it clicks but it doesnt turn over. i have already had the main relay fixed and it doesnt matter what temp it is. It started off when it took a few clicks till it would click and then start over, but now it rarely starts after many clicks. any ideas what this could be from?
Old Jul 6, 2006 | 12:22 AM
krongnome24
also when you turn the key it clicks once then a humming sound occurs until you stopped turning it.
Old Jul 6, 2006 | 03:54 AM
VPUPPY's Avatar
VPUPPY
Sounds like your on the right track. It could be the starter or the battery. How old is your battery?
Old Jul 6, 2006 | 08:09 AM
gingas's Avatar
gingas
Default starter
Yeah I have that similar problem on sometimes mine will click after several tries & then it'll fire up.I doubt it's your battery only because I've had my orig. one 4 yrs since had car. Is your motor stock? I have a B16 but not sure which starter will fit . Good luck
Old Jul 6, 2006 | 10:46 PM
krongnome24
well i cleaned the battery posts and now it starts every time so far. I think that was the only problem but we will see.
Old Jul 7, 2006 | 03:16 AM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
1st gen b16 with a cable tranny? 90-91 integra ls(manual tranny of course) starter will work.
Old Jul 19, 2006 | 11:28 PM
krongnome24
i know this post is old but i went to take off my starter to get it checked and i ended up running out of time at the last minute so i put everything back together. now it starts every time. does this mean my starter is going out? or maybe a loose connection.
Old Jul 21, 2006 | 07:36 PM
VPUPPY's Avatar
VPUPPY
Your starter is on its way out. If your battery shows 12.5 volts and you still get clicking, then its a starter problem.
