Starter help!
Old May 22, 2006 | 07:45 AM
georgelv1999's Avatar
georgelv1999
'92 black widow
Default Starter help!
Hi everyone, just wanted to know how to take the starter out of a 91 Civic Hatchback. If you can give detailed instructions, that would help. My starter is acting up, and won't start unless I hit the selenoid, which sucks. I would like to pull it out myself, so, if it's possible, I would like some DYI. Thanks.
Old May 22, 2006 | 09:58 AM
Disconnect the battery
Look around the starter itself for the bolts I think there are 3-4 of them...
Replace it and then reconnect...
not too detailed but its not that hard
Old May 22, 2006 | 12:04 PM
georgelv1999
'92 black widow
But can it be done without removing anything else. I mean, do I have to take anything else off the car before I can take the starter out?
Old May 22, 2006 | 01:38 PM
Exempt's Avatar
Exempt
2 tone Rex
Usually removing the intake tubing and air box (if stock) helps you get too it better... Maybe even the battery and tray also... Once all that is out the way, unhook the wires, I think theres 2 of them (one to the batt, one too the ignition), and then unbolt it from the tranny housing (theres 2 big 17mm bolts I believe), unbolt it, bolt new one back in, put the wires back on, reessemble whatever else u took out... Pretty easy repair...
Old May 22, 2006 | 02:47 PM
georgelv1999
'92 black widow
Ok, sounds like it's straight forward. I have to check it out too. Just wanted to know what I'm getting into before I do anything. Thanks a lot for all your help.
Old May 23, 2006 | 08:47 AM
mullinator's Avatar
mullinator
1. Drive down to the auto parts store.
2. Buy a Haynes or Chilton's guide.
3. Read it.
4. Then ask any remaining questions.
Seriously, these books are popular for a reason. They have some good info in there! There's no substitute for RTFM.
I also tend to own a factory service manual for my vehicles, as well. Especially useful for their troubleshooting checklists. Helps you avoid jumping to conclusions and swapping part$ for no good reason. -scott
Old May 23, 2006 | 10:06 AM
georgelv1999
'92 black widow
It's funny, I have a Hayne's one, and it says di-da-lly squat about how to remove the starter. You honestly think I would ask something without researching it. Every work I've done on my car I've researched it before performing it. That's why I asked. I'm not being defensive, but I wouldn't ask before looking into other threats. Or seeing the book.
