88 Civic not starting
Old Apr 24, 2006 | 12:56 PM
beasley@shentel's Avatar
beasley@shentel
Default 88 Civic not starting
Have fire to cyl. but no fuel. Can main relay be at fault? No whirling soung from fuel pump? Suggestions & instructions needed for possible fuel pump replacement.
Thx.
Old Apr 24, 2006 | 12:59 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
If its fuel injected then check the relay
Old Apr 24, 2006 | 02:21 PM
Tankard's Avatar
Tankard
Yea. Check the main relay first. If it's the main relay, you can fix it yourself, free of charge, if you have a soldering iron and some solder. Just search for main relay on this site, and you should find how it's done, if it's the main relay. I changed my fuel pump, and it ended up being the main relay.
