CRX Problems
Old Nov 22, 2005 | 12:09 PM
BColeman's Avatar
BColeman
Newbie ! ! CRX Owner
Default CRX Problems
Just bought a '91 CRX from a friend of mine. It has the stock block, but the head is a D16Y8.
The problem I have is three fold:
1) The fuel gauge doesn't work: fuel sender; relay; any ideas of where I can find the fuel sender (is it a part of the fuel pump).
2) The idler screw on the D16Y8 throttle body is frozen, meaning I don't idle, and I don't start that well. Any ideas of where I can appropriate one, even aftermarket performance. I don't intend to keep this setup, it will have a D16Y8 in it when complete, so an aftermarket Y8 TB will be fine.
3) Over heating: Anyone know where I could find the coolant hose that connects from the block to the head. I think there is a pin hole leak there...
I've been checking out this site for a couple of days now, and I'm thoroughly impressed.
Thanks for your help...
Old Nov 29, 2005 | 11:14 AM
BColeman's Avatar
BColeman
So can no one help me with this issue....
Old Nov 29, 2005 | 11:42 AM
mr.crx's Avatar
mr.crx
search!
Old Nov 29, 2005 | 12:42 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
what model crx is it?? an SI...
Old Nov 29, 2005 | 12:57 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
the hose is it the U shaped one in the back? Any parts store like Napa auozone or advance can help you out there.
Old Nov 29, 2005 | 01:30 PM
Tankard's Avatar
Tankard
Are you sure it's a pinhole leak in a hose? It could be a head gasket leak if you are losing coolant and not seeing it actually leak. As far as the fuel guage not working, check fuses, connections, etc.
Old Nov 29, 2005 | 08:21 PM
jdmeg6hatchy
i
hmmm. maybe for kicks you could get/rent a compression tester. They also rent out leak detector kits.
Old Nov 30, 2005 | 06:21 AM
jlicrx's Avatar
jlicrx
you say the head is a Y8 - are the intake manifold and throttle body also Y8? or does it have the Si D16A6 intake manifold? does the throttle body have the MAP sensor on top of it or is the MAP still on the firewall?
fuel gauge sending unit
File Type: jpg
File Type: jpg
Old Dec 2, 2005 | 08:42 AM
BColeman's Avatar
BColeman
First of all, I tried the search function, and didn't find the exact answers I was looking for.
The intake manifold and throttle body are the D16A6, and I've searched Honda Acura websites, eBay, nothing for a CRX Si Throttle body.
I never thought about the head gasket leak being the cause of the coolant leak. Since I wasn't the one who put the Y8 head on, I can't be sure if the gasket was replaced or if even the head was torqued right.
I think the model I have is the HF, but I'm not sure. It was originally dual point, but now has the Y8 head, A6 TB and IM, LS 1.8 injectors and resistor, and a ZC computer.
I just want to find the TB for now, I'll worry about everything else another day. The plan is to have an LS motor dropped in with a 5-sp. cable tranny by February of '06, but I would really love to drive it in the mean time.
Thank you all for your help in this matter, I really appreciate it...
