My VTEC Won't come on
Old Nov 24, 2005 | 09:27 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by LT
yea your light will still come on, because you probably have it wire to the oil pressure switch which still sends signal, but you wont have cam switchover. and if you have a gsr motor, the secondaries won't open either.
Exactly. A vtec light isn't the greatest method of determining if vtec is engaging or not, especially when it is saying that vtec is engaging when you are just revving it. You have to be going faster than 25 mph for vtec to engage.
Old Nov 25, 2005 | 04:34 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Thanx, I figured, but I use the light as an indication for VTEC. So I know if it kicks in at all. BUt for soem reason it jsut doesn't some times. Maybe I Just need to replace the IACV and the ECT Sensor and everything will be great. Well, I guess we will see, I will update later, anymore help, just post it up here. Thanx.
Old Mar 16, 2006 | 09:52 PM
RedlineBoyzCRX
EG6
I have had 2 broken retainers, just the outside broke, the inside was still hangin on there.
