My car died but will still crank??
I Need Help!! Yesterday My Car Just Died At A Light .. No Lights Came On In The Car When I Turned On The Heater It Just Died .. My Friend Has Checked The Plugs And Wires .. Im Getting Spark.. The Fuel Pump Is Working,.. No Fuses Were Burnt .. Batterie Is Opperating Correctly.. Tried Shooting Ether Into The Tube Thingy And It Still Wouldnt Fire.. We Tried Changing The Coil Pack And We Tried Changing The Ignigtion Conrol Module But Nothing Works.. Today We Are Going To Try To Change The Whole Distributor Is That Worth Doing .. Someone Please Help .. Damn Foreign Cars
89 CRX si, now with b16!
It should be either spark or fuel. Check the possibilities in that order. If the fuel pump is working, u could have an unplugged or clogged injector or injectors. If those two are ruled out, then u could have a bad ecu.
