1 Layer B Series HeadGasket
Old Nov 2, 2005 | 03:56 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Default 1 Layer B Series HeadGasket
Does anyone know where to get a 1 Layer B-Series Headgasket, I want to up my compression ratio, and I want to get my head shaved to .010, instead of
.020.
How much do they run. Also if anyone has a DIY on replacing the head gasket I would appreciate it.
Old Nov 3, 2005 | 07:06 PM
RedlineBoyzCRX
EG6
Bump!
Old Nov 3, 2005 | 08:12 PM
PacificDude's Avatar
PacificDude
Sharkbait OOHAHA!
A DIY for head gasket replacement can be found in any shop manual
Since you have done a B16A1 swap, get a shop manual for a car that came with that motor stock, this should supplement a manual for your CRX.
As for the 1-layer head gasket, idk. What I would do is call around to some specialty shops in your area and see who knows what you're talking about, then go from there.
BTW, I like the dark look to your CRX. It's kinda the direction I'm going with mine eventually.
Good luck!
Old Nov 4, 2005 | 04:41 AM
shivers's Avatar
shivers
Moderator Alumni
Spoon is the only one layer gasket I can think of at the moment.
2005 s2000
Old Nov 4, 2005 | 04:57 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
makes sure you clean the old gasket off entirely from the top of the block!!! The make a special remover that works real good! you can get it at AutoZone.
Old Nov 7, 2005 | 04:13 AM
RedlineBoyzCRX
EG6
I found the 2 layer SPOON headgasket, but I cant find a single layer one.
Old Nov 9, 2005 | 05:43 PM
RedlineBoyzCRX
EG6
Where can I get one?
Old Nov 9, 2005 | 06:37 PM
sherwood's Avatar
sherwood
I missed Sean
i'd stick with a 3 layer... but thats just me
