noise
Old Oct 25, 2005 | 01:15 PM
sketchsi's Avatar
sketchsi
Default noise
ok so all of sudden a noise starts coming out of my tranny its like if i put it in neutral and let out the clutch pedal it starts making a clicking noise and then i push in my pedal and the noise stops so thats how i know its something form my tranny but what and also when i take off in 1st its like it takes off normal and then all of a sudden it makes like a weird noise. they told me it could be my clutch that its already messing up or somthing form the clutch does anybody know wat it could be?
Old Oct 25, 2005 | 02:43 PM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
Your throw out bearing could be bad.
Old Oct 25, 2005 | 03:24 PM
sketchsi's Avatar
sketchsi
so that is part of wat the clutch
Old Oct 25, 2005 | 05:29 PM
jlicrx's Avatar
jlicrx
probably input shaft bearing in the transmission and not the throwout bearing - the throwout bearing only makes a noise when you depress the clutch, not with clutch pedal out - with pedal out, the throwout bearing is just sitting there doing nothing (unless, of course, you have a misadjusted clutch with no free travel) - with clutch pedal depressed, the transmission input shaft stops turning and if you have bad input bearing, the noise stops - let out the clutch and input shaft starts turning and with bad input bearing noise will start up
Old Oct 26, 2005 | 03:44 PM
ullerw's Avatar
ullerw
rexerk
um, i dont think thats correct, i believe it is the throw out bearing that is making that noise not the input shaft bearing, but if u can show me otherwise please do so for future reference for myself
Old Oct 27, 2005 | 10:53 AM
sketchsi's Avatar
sketchsi
this is a hard one i got to know which one it is cause wat if i buy the wrong part then im fucked
Old Oct 27, 2005 | 11:26 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Does the noise stop as soon as you press on the clutch or does it stop a few seconds after? If it is immediate, then it is the throwout bearing. If it takes a while, the input shaft bearing is bad.
If you are going in to replace the throwout bearing, it would be a good idea just to replace the whole clutch while everything is apart.
Old Oct 27, 2005 | 12:11 PM
sketchsi's Avatar
sketchsi
its like as soon as i press the clutch the sound slowly fades away. could that noise be the reason why i cant shift good when racing .
Old Oct 27, 2005 | 12:21 PM
Provocateur
On permanent hiatus
Yeah, there is probably something internally wrong with the transmission.
I had a bad throwout bearing and as soon as you put your foot on the pedal, the noise would immediately stop.
Old Oct 27, 2005 | 12:27 PM
sketchsi's Avatar
sketchsi
so you think its the input shaft bearing then
