Electrical problems...
Old Oct 16, 2005 | 04:47 AM
shady visions's Avatar
shady visions
Default Electrical problems...
So, my CRX hasn't been able to start properly without a jump for the past few months. Now I can't get it to start WITH a jump. All that happens to the battery is a big spark and then I lose all power.
Old Oct 16, 2005 | 05:22 AM
VPUPPY's Avatar
VPUPPY
what do you mean a big spark? try cleaning and tightening your battery terminals. if your car runs fine after jumping it, then your battery is bad. if your car does not run for but a few seconds after jumping it, its your alternator.
Old Oct 16, 2005 | 02:47 PM
shady visions
My car runs fine WHEN i can get it started by jumping it.
In the past month it hasn't started once. When I jump it, I turn the key over, I have power, and then I turn it to position three and all It does is spark and lose power with the cables still attached. It sparks at the cables.
Old Oct 18, 2005 | 12:32 AM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
I think you've had this problem before.... Double check your ground cable. My crx did the SAME EXACT thing, and it turned out to be the ground. Move that ground to a different spot ASAP. Once I fixed that, a couple months later, it did the same thing again, but this time, the battery was going dead.
Old Oct 18, 2005 | 07:48 AM
shady visions
problem fixed a little while ago.
bad ground wire + battery (dead cells, 2).
