rear disk conversion - alignment
Old Oct 4, 2005 | 08:10 AM
parkerfly's Avatar
parkerfly
I pulled the struts off last night and found they don't match? Although this can't be good and I definately need to replace the strut I'm not sure that would cause problems with alignment.
Does the weight of the car even out any length differences in the strut? Not sure if I found "the" problem... or just another one.
Old Oct 4, 2005 | 08:18 AM
Caster Troy SI's Avatar
Caster Troy SI
bye ashley, hello leah
it very well might be the problem. while you were down there did you compare the compensator arms?
Old Oct 4, 2005 | 08:47 AM
parkerfly's Avatar
parkerfly
Its hard to measure on the car when your looking for such small differences but they are at least really close. I haven't pulled them off because I found the sleeve inside the frame of the car is loose on the drivers side so it just spins once it gets loose.
Old Oct 4, 2005 | 06:10 PM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by parkerfly
I did this and found they do have different part numbers. I think they are pretty much the same thing though, just stronger.
Often times, Honda and Acura will have different part numbers for identical parts... sometimes even two numbers within the same brand devision for the same part.
Old Oct 18, 2005 | 07:58 AM
parkerfly's Avatar
parkerfly
Default Back to the drawing board
Put the new struts on but as it turns out that was just "a" problem, not "the" problem. The drivers side rear of the tire is just not out as far as it should be for some reason.
Here is a pic to compare the 2 sides...
