difference: synthetic vs regular
Old Sep 15, 2005 | 02:08 AM
Tankard's Avatar
Tankard
Originally Posted by mistacee
You're pretty cool.
I have searched, way before this topic ever came up,but this is an age old arguement and one of those questions where everyones answer differs. I suppose i could have expanded my thought and been more specific. Since i have heard different answers for the "Can you go from synthetic back to reg oil?", i figured i would get some opinions and/or thoughts.
If you did'nt figure it out, i was just doing you the same way you do others.
Old Sep 15, 2005 | 02:45 AM
mistacee's Avatar
mistacee
Zc powered ED9
I figured thats what you were doing,so thanks i guess
Back to the oil topic,I just may say fuck it and next oil change let the synth. oil drain as much as possible and put regular oil in it.
Old Sep 15, 2005 | 03:18 AM
mrbkkt1's Avatar
mrbkkt1
Aiea, HI
i use synthetic in my car. i put dino oil in the v6 accord, had full synthetic in my s-10, and ran a blend in the civic. only time that anyone can seriously say synthetic is not better than dino oil is during breakin, where the hard core racers swear to break in your motor w/ dino oil.
Old Sep 15, 2005 | 04:27 PM
ullerw's Avatar
ullerw
rexerk
mistacee, try a synthetic blend before going straight to regular oil, i do not know why, but my friend works for an oil change shop and that is their recommended procedure
Old Sep 16, 2005 | 12:22 PM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
I read an article once that laid out 2 general rules for synthetic:
1. If you have a low miles motor(~50k or less), switching to synthetic should prolong engine life and seals.
2. If you have more than 50k miles, don't bother switching to synthetic, as seals, by this time, have gotten used to dyno oil, and the composition of synthetic oil can allow oil to seep into the combustion chambers.
I think the second rule is just opinion, though. Changing to synthetic for 1 cycle shouldn't hurt your car, then you can see the difference for yourself. Also, if you just had a rebuild less than 2k miles ago, I would DEFINITELY switch to synthetic.
Old Sep 21, 2005 | 11:26 AM
mistacee's Avatar
mistacee
Zc powered ED9
Thanks ,i never even thought of doing that! I completely forgot that they make a synthetic blend.
Old Oct 16, 2007 | 10:21 AM
stella-man1's Avatar
stella-man1
Default honda crx vti
hi there, iv just bought a chip 4 my crx and was wondering about wt oil to put in it, i want to put fully sinth in but im really not sure wt to do, the milage says 150, so should i put semi synth in thanks alot
Rob
