Update on Problems...
Old Aug 15, 2005 | 06:39 PM
VTEC-Power's Avatar
VTEC-Power
I also picked up a Haynes manual, so I will attempt to do the fuel injector swap myself, I hope I do it right
Old Aug 15, 2005 | 06:54 PM
VPUPPY's Avatar
VPUPPY
make sure you get new o-rings for the new injectors and you should be fine.
Old Aug 15, 2005 | 07:21 PM
B18C Turbo's Avatar
B18C Turbo
yeah dude, dont forget to get new seals from your local auto parts store, its sooo easy to install new injectors. $500 for used exhaust? I got a no name 2.5" mandrel bent tig welded full catback for $115 shipped brand new in the box, with hardware and gaskets, weighed in about 30lbs or something lighter than stock and sounds great and performs awsome.
As for injectors, when you get your turbo kit together, get some DSM 450's or Tunertoys 450,550, or 660 injectors, they are $200 NEW w/ new seals and are exactly like RC's.
Old Aug 15, 2005 | 07:36 PM
VTEC-Power's Avatar
VTEC-Power
where can I get some o-rings and seals? pepboys? and will the b16a2 o-rings and seals fit my injectors even though those are 0BD1
Old Aug 15, 2005 | 07:41 PM
VTEC-Power's Avatar
VTEC-Power
aren't o-rings, seals?
Old Aug 15, 2005 | 10:02 PM
VTEC-Power's Avatar
VTEC-Power
will the b16a2 o-rings and seals fit my injectors even though those are 0BD1? and o-rings are the seals correct? need to know so I can buy them
Old Aug 15, 2005 | 10:16 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
They should. Assuming your injectors are 240cc, they will fit.
Old Aug 16, 2005 | 06:47 AM
VTEC-Power's Avatar
VTEC-Power
thx
Old Aug 16, 2005 | 02:38 PM
VTEC-Power's Avatar
VTEC-Power
checked it out 00 Si injectors are 240cc so I guess I am getting those o-rings
Old Aug 17, 2005 | 06:49 AM
VTEC-Power's Avatar
VTEC-Power
I looked in the Haynes manual and it does not tell you how to change the fuel injectors, is it as easy as unplugging them, taking them out, putting new o-rings on the new ones, and plugging them back in? if not can I have step by step info
