car codes
Old Jun 12, 2005 | 11:01 PM
spazz0nater's Avatar
spazz0nater
i wanna go fast
Default car codes
what do you use to read codes?
Old Jun 13, 2005 | 02:05 AM
jc836's Avatar
jc836
IF you mean the VIN, then the final 6 are the serial # and the frist part relates to the trim level. For example-JHMED9 is the code for a Japan built CRX Si.
If you are asking how to read the CEL codes-there is a window on the ECU. It is mounted under the passenger side carpet. Just peel it down and watch as you turn the Ignition switch to the ON position. If everything is OK you will get 1 quick flash. Do this where the light is fairly dim, btw.
You can also check how the MAIN relay functions by turning the switch to the ON position. You will have a CHECK light on the dash which will go out after ~2 seconds. You will also hear the fuel pump run during this time as it primes the system.
Old Jun 14, 2005 | 11:10 AM
spazz0nater
i wanna go fast
but when people say thay have engine code 43-44-1 how do they get this?
Old Jun 14, 2005 | 12:35 PM
pnthr30's Avatar
pnthr30
AutoZone can read them for you........ :dunno:
Old Jun 14, 2005 | 08:45 PM
flatliner's Avatar
flatliner
Fix It
the passenger kick panel there is a little 2 wire plug not plugged into anything or mabye locked into a green rubber holder, simply hook a paperclip into the 2 prongs and turn key on,. read the flashes
Old Jun 14, 2005 | 08:52 PM
spazz0nater
i wanna go fast
so there is no reader were i can plug it in and it says a number. And were to i translate the flashes?
