Don't know what engine code
Old Jun 12, 2005 | 04:41 PM
ED9man's Avatar
ED9man
driver
Default Don't know what engine code
long blink, long blink, short blink, short blink, short blink.
JDM first gen B16a with matching PW0 ECU. That should be 23 but it isn't a real code. There is no pause between the blink except for a long pause when the sequence starts again. I cut ignition and turn the car back on and it goes away and does not come back. Seems to happen when I am low on fuel.
Old Jun 12, 2005 | 05:30 PM
Kai's Avatar
Kai
Rotorphile.
23 is the knock sensor.
Old Jun 13, 2005 | 11:01 AM
ED9man's Avatar
ED9man
driver
You sure? I have the manual for the car on my computer and it isn't listed.
Knock is bad. Could a lean condition cause knock? I know the car is running lean.
Old Jun 13, 2005 | 11:06 AM
qtiger's Avatar
qtiger
Does that engine even have a knock sensor in the first place?
Old Jun 13, 2005 | 11:45 AM
Fire's Avatar
Fire
wanna run
most definitely
Old Jun 13, 2005 | 01:34 PM
ED9man's Avatar
ED9man
driver
it does.
What is timing supposed to be at idle? I used a gun and it was 15 degrees advance. Maybe if I set it back a hair I could solve this issue since it was designed to run on better gas in Japan?
Old Jun 13, 2005 | 03:05 PM
Kai's Avatar
Kai
Rotorphile.
Hell yes!
Sure, all DOHC VTEC engines have had them from day 1.
Old Jun 14, 2005 | 08:48 PM
flatliner's Avatar
flatliner
Fix It
if you are lean and advance then it is picking up some real noisy crap. The knock is so the computer knows where the base timing sould be leveld to optiminum advancement at driving conditions, lean advanced and cheap gas is opt to cause detonation pinging sending the computer into a fit of panic... you like that?
Old Jun 15, 2005 | 11:19 AM
ED9man's Avatar
ED9man
driver
I don't run cheap gas.
I checked the advance and it is in spec so it must be the lean condition.
