In a little jam - help with exhaust and sway bar.
Honorary Moderator Alumni
I recently purchased an A'PEXi WS exhaust because I purchased a 1991 Civic Si with a straight exhaust. Too loud for some of the events in this area.
Went to put it on and ran into a problem. The car I purchased has a Suspension Techniques rear sway bar and I'm having a fun time trying to figure out how to get the one pipe over/around the sway bar.
Has anyone run into this problem? If so what did you do?
Thanks!
Mike
Thanks!
Mike
Autocross Help Page
Autocross Help Page
Aftermarket exhausts are designed around the stock bars. They usually have very tight clearences over the stock bars even to keep the pipe as straight as possible for maximum flow. Bigger bar = not enough clearance sometimes.
Autocross Help Page
Autocross Help Page
On permanent hiatus
I really depends on the exhaust. The Evo that I have has plenty of clearance over my Comptech swaybar and was easy to put in. The two options you can opt for is either put a stock swaybar back on or buy a different exhaust.
wooo nascar!
i remember reading a little disclaimer thing when i ordered my sway bars for my civic that said it may interfere with some aftermarket exhaust systems. i guess its a good thing i changed my mind on that exhaust, cuz i was gonna get that along with those same sway bars.
im choosing a more economical route and getting a new stock mid pipe from napa for like $80 (my resonator is rattling like a bitch right now) and just getting the tenzo axle-back for like 150. ive had the WS on my old civic and my teg and absolutely loved it, but if its not gonna work with the sway bars im getting, forget it. i know someone with the stock b-pipe and tenzo axle back and i like how it looks/sounds/performs.
i remember reading somewhere that mugen discovered that there is little to no gains made by replacing the mid pipe with a larger diameter pipe. the muffler (axle back) is where the restriction is in the oem exhaust, so just replacing the axle-back is where you'll see the most bang for your buck.
i understand though that your current exhaust may not route the same as oem, and then buying a whole new cat back would make sense.
if you're really stuck on keeping that exhaust, maybe you could try another brand of sway bar. im pretty sure eibach makes bars for the EF. you could sell the ST bars to me
