85 CRX DX Fuel Injection Conversion
I have a few 1985/87 models Honda CRX DX and I wanted to convert one of them to a fuel injection car. What components am I going to need to do this (as far as sources)? I would prefer to use new parts if possible. Maybe a kit available to perform this swap? I have no idea, I don't deal with Hondas. I'm a Ford guy, but since I'm stuck with them, I might as well play with them a little bit.
Thanks for the input!
Rotorphile.
Maybe a kit available to perform this swap? I have no idea, I don't deal with Hondas. I'm a Ford guy(...)
There really isn't much to do... have you ever considered a head swap and a intake manifold and carburator upgrade?
Well as far as the kit idea goes, it was an idea
I'm not concerned with the cost, its going to be a sponsored racing car. The car is going to be for a younger friend who just turned 15 and is just getting into the racing scene. I'd rather he be at a track under supervision and safety coordinators than out on the streets risking his life. Fuel injection was something I wanted for the vehicle, primarily for the fuel return so that any unused fuel would be simply returned to the fuel tank. It is true, there are "kits" that I can buy to convert CFI to EFI in a Ford vehicle, but surely that isn't the only brand that has a kit or assembly of parts that can be purchased to ease the conversion of one fuel system to another? Okay, since there isn't a kit and I don't have a donor car on hand, what components am I looking at for the conversion?
"install an Si tank with its high pressure fuel pump, run new fuel lines to the front, and peice together a Haltech system (WAY overkill for that car.)"
I am not familiar with a Haltech system, could you inform me?
If I have to buy the components, what are some good websites that I can buy the parts I need to make this happen?
Thanks!
Thanks!
Rotorphile.
The car is going to be for a younger friend who just turned 15 and is just getting into the racing scene. (...) Fuel injection was something I wanted for the vehicle, primarily for the fuel return so that any unused fuel would be simply returned to the fuel tank.
To be perfectly honest, if you have to ask about converting a 3G body to fuel injection, you probably can't do it. You either need to swap in the complete system from an Si or do a hybrid Si and stand alone EMS swap. Coming from Fords to Hondas is pretty much like moving from the US to Japan... you have to learn everything over again.
I don't mean to discourage you, but this isn't a simple job.
