84 CRX idling *really* low and stalling
Old Jan 14, 2005 | 04:20 PM
marshacrx's Avatar
marshacrx
Default 84 CRX idling *really* low and stalling
Hello. Car runs great, for an hour, sometimes 2hrs, then when stopping, starts idiling very low, then almost stalls. Unless I give it gas with emergency break on, it would stall. I am suspecting a carburetor adjustment????? maybe something was knocked loose when I went too quickly over a ditch/bump a few days ago.
I'm trying to get ideas before I break out the screwdriver. Thanks!
Old Jan 14, 2005 | 10:20 PM
augy's Avatar
augy
Basic stuff: air filter, fuel pump would be my first guesses after carb adjustment.
Old Jan 15, 2005 | 12:01 AM
Kai's Avatar
Kai
Rotorphile.
A fuel filter would help too, but probably has nothing to do with the problem.
Try the easy fix first, adjust the idle up. If that doesn't work, it could be a carb problem. Has it ever been rebuilt? A carb that old would probably need it by now.
Old Jan 15, 2005 | 01:37 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Change the idle screw on the throttle bodsy, it should be a gold screw.
Old Jan 18, 2005 | 02:59 PM
MattCook's Avatar
MattCook
With the '84, this could easily be a vacuum hose problem. The SI (I don't know about the others) had over 84 vacuum hoses, and two plastic boxes filled with little vacuum components. I took mine to two dealers and they both told me the same thing. When an '84 CRX gets a vacuum problem, it's time to throw it out. I replaced almost all the vacuum hoses, and tried a bunch of other things, payed a dealer over $1500 to try to find it, but to no avail. I wish I'd saved my money for a new CRX, or at least a new engine (without the vacuum hoses this time).
Old Jan 18, 2005 | 03:46 PM
Kai's Avatar
Kai
Rotorphile.
That's why I reworked the vac system on my old '87 Si. I took it down to less then a dozen and it ran peachy.
Or, give it to someone like me.
Old Jan 21, 2005 | 07:54 PM
augy's Avatar
augy
carbureted engine, buddy
Old Jan 24, 2005 | 03:14 PM
MattCook's Avatar
MattCook
The '87 is a lot easier to deal with than the '84. The 87 is fuel injected, and the vacuum hoses are kept to a minimum. Try that with the 84 + hoses in an '84.
Old Jan 25, 2005 | 05:15 AM
Kai's Avatar
Kai
Rotorphile.
Only the Si. All other models still used a single carburator. There was no '84 Si, just an S (the little "i" means it's fuel injected.)
