87 si head swap
Old Jan 12, 2005 | 06:52 PM
kevo2k6's Avatar
kevo2k6
Default 87 si head swap
from everything ive read the 86-87 integra head (d16a6) with bolt up to the 87 si block (d15a3). if i am wrong tell me. otherwise im gunna tyr and locate one to try it. has anyone attempted or acheived this?
Old Jan 12, 2005 | 06:55 PM
VRCCRXsi's Avatar
VRCCRXsi
Vendetta Racing Crew
i was looking into the same thing... replacing the head on my 87 si block... (d15a3)... i just wasnt sure what would fit... somebody help us out!!
Old Jan 12, 2005 | 09:28 PM
91_CiViC_RiDeR's Avatar
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Go Here!!!
click above link
Old Jan 12, 2005 | 09:38 PM
VRCCRXsi's Avatar
VRCCRXsi
whats the difference between the d16a6, d15b1, d15b2... wich one will give more power and bolt on without too much of a hassle?? and would a d16a1 fit??
Old Jan 12, 2005 | 09:43 PM
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
the d16a6 will have more power than the d15's...They will all bolt on with little or no mods and as far as the a1 i am not too sure about that but if you do a search and type in Mini-Me you will be able to find quite a bit of write ups on here!!
Old Jan 13, 2005 | 02:48 AM
Kai's Avatar
Kai
Rotorphile.
Holy Christ, you guys don't know what's going on.
You mean a D16A1 head. That's completely different then a D16A6 head. Fitting a ZC type DOHC head to a D15A3 isn't impossible, it is just very impractical to the average home mechanic. If you want more details, ask.
There is no (better) head that can easily swap onto the D15A3 block. I'm a former '87 Si owner myself, I looked into it before only to find no easy solution to the 12v non-CVCC head problem.
Originally Posted by 91_CiViC_RiDeR
That has nothing to do with E-type (early D-series) engines unless he is willing to rewire the entire car.
A lot, none of which had to do with 3G cars.
An 86-87 D16A1 is a bolt-in job to an 84-87 Civic/CRX.
No. Just, no. :doh:
Old Jan 13, 2005 | 12:07 PM
kevo2k6's Avatar
kevo2k6
thank you kai! u gave a lot of useful info. now would it be helpful to put the D16A1 head on my crx block? woudl i be able to find things suchs as headers or cams any easier. and once i switch to that head are there other blocks that work with the D16A1 head? and jsut to clear it up the D16A1 is dual cam isnt it? ill need a new timing belt rite? thanks for ur help.
Old Jan 13, 2005 | 03:36 PM
Kai's Avatar
Kai
Rotorphile.
Helpful, yes. Hard, yes. The block needs be be drilled out and tapped to use an Integra head bolt in, if memory serves, the middle rear location. The cooling ports should line up close enough to work. The main problem is the timing belt... there is no stock timing belt that will work. You have to use, I believe an old Accord crank pulley, and a special sized genaric timing belt trimmed a bit narrower to fit. This isn't a normal head swap, I've only heard of it being completed once by a specialty racing shop to get a 1.5L DOHC to fit regulations of a certain racing class that wouldn't allow a 1.6L block. Search redpepperracing.com for more details.
Yes, the D16A1 uses a standard modern D series exhaust manifold bolt pattern. ZC cams are a direct swap.
You should install a complete D16A1 engine, not just the head. It will make more power. The D16A1 head is compatable with all DOHC ZC pattern blocks, but you'll need to stay with a D16A1 or a browntop ZC..
Yes.
Old Jan 13, 2005 | 03:45 PM
VRCCRXsi's Avatar
VRCCRXsi
what would be a better swap, the d16a1 or a b18b1???
Old Jan 13, 2005 | 03:48 PM
Kai's Avatar
Kai
Rotorphile.
A D16A1, simply because you can get one of those in and running for under $1k. Plan on spending $4K+ to get a B18B in there.
