Gauge Cluster Lights Problem...
Old Nov 9, 2004 | 12:17 PM
m735is's Avatar
m735is
Have you found a wiring diagram for that year?
Old Nov 9, 2004 | 12:50 PM
redcivicforever's Avatar
redcivicforever
no I don't even have my manual its at my dad's house in a box and I have to find the time to go over there and look for it so it probably won't be soon unless I can find one online or something...
Old Nov 16, 2004 | 07:08 PM
oneslowrex's Avatar
oneslowrex
Do all the cluster lights go out? Or only certain ones or a certain side? I've seen this problem lots where the filament in the bulbs gets a very minor break in it and when it gets cold it pulls the filament apart just enough to not make a full connection. But as it warms up it'll pop back on by itself. I had that happen recently to my crx when it started getting colder here and just went ahead and replaced all the bulbs in my cluster.
Old Nov 17, 2004 | 11:09 AM
redcivicforever
well, the gauge (dash behind steering wheel) lights go out entirely and then pop back on whenever it gets warmer but not immediately just whenever... since the cold weather has been for the past few weeks they went out when it started and have stayed out...so what your talking about makes perfect sense with the problem I have so I need to tell the mechanic who will do it to replace the bulbs or filament? thanks for the help!
Old Nov 18, 2004 | 03:58 PM
oneslowrex's Avatar
oneslowrex
No problem. Glad I could help.
Old Dec 2, 2004 | 06:32 AM
redcivicforever
Default Progress?
Well, I just had the bulbs replaced on the gauge lights thats what I was told it needed and they worked! ...then they stopped working ...then I hit a bump and they were working again! yay!...then I hit another bump, now they don't work again. They also look super bright, unnaturally so and they weren't before when they are on anyway, and there are brighter and dimmer parts on the gauges which there didn't used to be. Does anyone have any ideas what would make these things happen?
