Coolant leak????
Old Oct 26, 2004 | 08:51 AM
crx87si's Avatar
crx87si
Durkedurkistan
Default Coolant leak????
Yesterday morning started the car to warm it up and it started dripping from the driver's side bottom of the motor. Is this where the water pump is? How hard is it to put a new one in?
Tony
87 CRX
Old Oct 26, 2004 | 09:12 AM
Pete's Avatar
Pete
Civilian
It's most likely just your resivoir. I get drips there all the time. The actual coolant system is mounted on the front of the car. When it heats up, some of the coolant will over flow into the resivoir. Make sure the tubes are tight and the cap on your resivoir is tight. Check the seals on all the spots were tubes come out and go in. It's probably nothing too serious.
Old Oct 26, 2004 | 02:13 PM
augy's Avatar
augy
yeah, take a closer look and see where precisely it's coming from
Old Oct 26, 2004 | 05:18 PM
v8guy's Avatar
v8guy
Professor
The timing cover is on that side of the engine, and inside it lurks the water pump. If coolant is dripping out of the timing cover, it's time for a new water pump and timing belt.
Old Oct 26, 2004 | 07:12 PM
crx87si's Avatar
crx87si
Durkedurkistan
The coolant tank is on the opposite side that the leak is on, so I'm looking at a new timing belt and a water pump it appears.
Old Oct 26, 2004 | 08:01 PM
augy's Avatar
augy
I don't know what an 87 crx engine bay looks like, but be sure that it isn't something cheap and simple like your radiator or heater hoses. I own a 2nd gen crx, and none of my coolant-carrying hoses are on the driver side except the resevoir, so I'm going to guess that yeah, the seal around your water pump has been compromised. God does speed with the black emperor... or something... I mean, good luck
Old Oct 27, 2004 | 09:47 AM
crx87si's Avatar
crx87si
Durkedurkistan
Took it to the shop this morning, the water pump is shot. $400 to replace the pump, timing belt, and valve cover seal. It'll be done tomorrow.
