drilling...
Old Oct 17, 2004 | 09:26 PM
augy's Avatar
augy
Default drilling...
Well, I bought some rear seats off of ebay for my 89 crx, and I'm gonna need to drill some holes to mount the seatbelts to the chassis with. My dad has a 3 amp drill, I don't know if that's enough. I've never drilled a hole in my car before, so if somebody has something to say, "Now's the ****ing time!"
thanks.
Old Oct 18, 2004 | 12:00 AM
Kai's Avatar
Kai
Rotorphile.
Make sure there's nothing on the other side of the planned hole... like the gas tank.
Holes in the gas tank is a bad thing.
Old Oct 18, 2004 | 12:09 AM
Civic2Scooby's Avatar
Civic2Scooby
brake lines, fuel lines, and electrical wires, are also good to check for first.....h:
Old Oct 18, 2004 | 08:36 AM
augy's Avatar
augy
Yurp.
Will do.
howsaboot the amperage of the drill, though? Is 3 enough or am I gonna hafta go spring for another drill?
Old Oct 19, 2004 | 08:22 PM
Muddy9069's Avatar
Muddy9069
That drill should be fine... Your drill bits will be what you should worry about. Get a good carbide tip bit.. otherwise you will probably be spending a long time and a few broken bits getting through. Carbide bit will cut it like butter
Old Oct 19, 2004 | 11:24 PM
v8guy's Avatar
v8guy
Professor
Center punch where you want the hole to be so the drill doesn't walk around, then drill a small pilot hole and then ream it out with a larger bit to the size you want.
Old Oct 20, 2004 | 12:42 AM
Kai's Avatar
Kai
Rotorphile.
Center punches are for pussies... and cheap guys like me. If you can't hold it there by yourself, you're not good enough to drill a hole there. :chuckles:
But really, a punch is a good thing to have. If not, at least use a large nail or something to get a similar effect.
Old Oct 21, 2004 | 09:48 AM
augy's Avatar
augy
I guess this job will really put some hair on my chest.
