Finally decided.....
Old Aug 13, 2002 | 05:55 PM
rynxprs's Avatar
rynxprs
Default Finally decided.....
Thanks for all your help on my decision on getting a CRX.
I've decided on an 88 Si. Mostly due to the price $500. :thumbup: But it does need some work to get it to where I want it. Which is the fun part.
Anyway...First thing First....ENGINE SWAP.
From what i've read the B16 is a majority favorite.
Is this a good choice to go with instead of the B18 or the ZC?
So where can i pick one up? (or have it shipped)
I'm looking for a good price...quality engine...reputable company.
I have Search for info on Swaps.
Now I also here that there is the B16a1 and B16a2.
I am a First Time Honda Owner so i'm not familiar with the Engines.
Which should I go with? Which would be easier?
Other then Motor Mounts and the engine, what else should I get for my 88 Si?
Thanks again...i'll be around with alot more questions.
Old Aug 14, 2002 | 07:18 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
No matter what engine setup you get, you should make sure that you get an engine/tranny combo that includes a CABLE operated tranny for the clutch operation, and a factory LSD would be a very nice touch as well.
The B16a1 is a JDM engine, 1.6L DOHC VTEC rated at either 160 or 170HP depending on specifics. This is a swap favorite because it fits fairly easily into a CRX [it was factory on some JDM cars, so there ya go...], and due to the numbers in which it was made, is readily available very cheap.
The ZC is another JDM engine, and can be found in either a 1.5L SOHC VTEC configuration or a 1.6L DOHC non-VTEC, both of which make around 130 HP.
B18's can come in several varieties, all of which are DOHC and 1.8L in displacement. The B18a/B18b engines, commonly referred to as an LS engine [even though they were also found in Integra RS's, and GS's] are non-vtec engines with good torque, about 140ish HP stock, and a fairly low compression ratio which makes for a good turbo candidate. The B18c is can be found in the newer GSR's, DOHC VTEC, makes a bit more power than the SiR version B16, and has more torque. The B17 engine was also DOHC VTEC, 1.7L and is basically a sister-engine to the B16. The B18C5 came from the Integra Type R's, 190ish HP stock, high revving, high compression.
The main concern with B18's in a CRX is block height, since this was a major concern a few years ago, and the head could hit the hood. Place racing and HASport mounts have pretty much eliminated this concern, just be aware that there could be such a problem. Beyond that the only other major problem is that the factory intake manifold on a B18c will not fit in the engine bay, it will hit the firewall, the LS, and C5 don't have this problem.
If it were up to me, I would go with a B series engine over a ZC for the simple fact that there are lots of transmission and gearing options available without sorting through the relatively undocumented area of D-series transmissions.
-Harry
AIM: NDcissive
93accord4door
Accord
31
Jan 8, 2004 05:06 PM
thork
6
Dec 27, 2003 01:05 PM
The G2 Racer
May 17, 2003 10:43 AM
crucial Si
92+ Civic/EL & Del Sol
12
Apr 3, 2003 05:12 PM
DanM
Engine Swaps, Tech & Tuning
3
Mar 31, 2003 10:28 AM
