Yet another STUPID question!!!!
Old Aug 1, 2004 | 09:24 AM
91_CiViC_RiDeR's Avatar
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Default Yet another STUPID question!!!!
Ok I have another dumb question that I pretty much know the answer too but I want to be sure before I do anything, so here it goes.....My Civic is slanted to the right when you look at it(DRIVER SIDE). And whenever I go over speed bumps or any kind of bumps it makes this squeaking noise from the front driver side. I want to know if that is my suspension going bad and if it is what part of it???? I know its not my brakes or clutch or anything of that sort at least I dont think it is I am sure it is my suspension but I just wanna make sure!!!!!! THanks in Advance!!!
Old Aug 1, 2004 | 05:33 PM
ED9man's Avatar
ED9man
driver
turn off your annoying blue text.
that sounds odd, I don't know, bad balljoints?
Old Aug 1, 2004 | 06:58 PM
jaje's Avatar
jaje
HC Racer H5
sounds like your springs could be bad (maybe even broken on that one side)...how much slanted is it?...you could take measurement of the wheel gap (gap between the tire and the fendor) on each side to make sure one side is lower
Old Aug 1, 2004 | 07:23 PM
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Well I know its low just by looking at it from the front. I mean all my tires are good cause I just got them all replaced about 3 to 4 days ago. But anyways I just checked them and it's a right at an inch difference from driver to passenger.
Old Aug 2, 2004 | 09:58 AM
LSVTECKING's Avatar
LSVTECKING
rebuilding
It sounds like your strut is bad and you spring is taking all the punishment. Go over some hard bumps and see if it clunks. if it does get some new struts. If it doesnt then your springs are prob. shot.
Old Aug 2, 2004 | 01:03 PM
Kai's Avatar
Kai
Rotorphile.
Agreed, it's between a blown shock and a sagging spring.
Old Aug 2, 2004 | 09:37 PM
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
Well it doesn't clunk and I took a good look at my springs today and found out that it is just my springs gone bad....So I am going to go ahead and replace them and see if it works....But first I need to find out how to put new springs on since I have never done it myself ....... lol.....
Old Aug 3, 2004 | 12:51 AM
Kai's Avatar
Kai
Rotorphile.
It's easy, as long as you have a spring compressor.
Old Aug 4, 2004 | 10:29 PM
menappi's Avatar
menappi
hey i had the same problem, and i took my suspension apart in the front end and found out that on of the bushings that goes on the top of the strut was MISSING!!! putting springs on is easy and u dont really need a compressor either..but it would be safer.. just put weight on it and have someone unscrew the bolt making sure it doesnt hit anyone in the face HAHAHAHA!
