Rear disc swap
Old Jun 2, 2004 | 03:23 PM
cwhiteboy's Avatar
cwhiteboy
Default Rear disc swap
Ok, I already know how to do a rear disc swap, but there is one thing that I can't figure out. Which e-brake cable should I use? I have a 90 crx hf, and I bought the rear trailing arms from a 90-93 integra (with everything but the e-brake cable). Will my stock e-brake cable work, if not, from which car should I get one? Thanks for any help or advice.
Old Jun 5, 2004 | 08:22 AM
90_crx_flaze's Avatar
90_crx_flaze
Drift King
i read somewhere u can use the ones off the teg but there longer and have to be routed different, i also read that u could drill out something on the brake and swap the cables
Old Jun 5, 2004 | 11:45 AM
schwanginpt's Avatar
schwanginpt
Nadene will Return
teg cables would work, but as said, i think they have to be routed different. if you can get your hands on 90-91 CRX Si cables, they would work for your application the best.
Old Jun 6, 2004 | 08:19 PM
cwhiteboy's Avatar
cwhiteboy
thanks guys.
Old Jun 6, 2004 | 11:56 PM
onecommonvoice's Avatar
onecommonvoice
You may not need everything but it's good to have!
90-93 Integra Rear Trailing Arms (with everything attached Rotor, Caliper, Ebrake Cables...)
or
90-91 CRX Rear Trailing Arms (with same...)
You can use either trailing arm but for CRX you need CRX ebrake cables and for Civic you need Integra ebrake cables (might as well get whole CRX trailing arm + cables for CRX, and whole Integra trailing arm + cables for Civic)
90-93 Integra "4040" Brake Proportioning Valve (Prop Valve), HIGHLY RECOMMENDED!!!
d21x
Accord
10
May 27, 2004 10:03 AM
Spike
92+ Civic/EL & Del Sol
15
Jan 23, 2004 08:43 AM
ketchup
CRX & Pre 92 Civic
3
Oct 31, 2003 01:09 PM
EJ6 Civic
May 20, 2003 01:33 PM
egjoe
May 16, 2003 01:01 PM
