what else? can I use the Si harness? or do i need the hasport one too? why does hmotors sell the complete change over then? Can I use the shift linkgage?
they sell the complete change over because it is easier to just rip the bitch out the car and seran wrap it up then try and part it out. you can use the Si harness.
my car is a dx but I converted to an si and added the wires...does that matter? And it has a 4spd tranny so i will need knuckles from a acura or si right??
correct....as long as you converted to the PGM-FI then you will be fine with the swap, and I am pretty sure you need the knuckles from the acura but not positive on that one.
thanks alot..how about the linkage..should i get that from hasport..? where did you get your b16a? so I don't need the harness from hasport right but I do need mounts...what about axels?
I got my motor on a hook up through a friend. I used a GSR half shaft with GSR axles because they are the easiest to get replacements for if you blow them out. you shouldnt need the harness if you already changed over to si harness.
Does anyone know which if I can use the shiftlingake from a acura??? and which year should I use??? And if I need acura axels and knucle... hub as well???
