Hatch leaking AGHHHH
Old Mar 17, 2004 | 03:50 PM
crxsiperf's Avatar
crxsiperf
Default Hatch leaking AGHHHH
My hatch is leaking on the passneger side right outta where the hatch strut is , water dripoping right down onto my speaker , i replaced the seal and its still leaking , is there somewhere else water could be coming in at and just decending to that spot then dripping?
Old Mar 19, 2004 | 08:06 PM
shawn_crx8891's Avatar
shawn_crx8891
i have the same problem, only on both sides. if you find out let me know cause my whole driver side floor gets puddles (cause i don't have carpet). thanks.
Old Mar 19, 2004 | 08:14 PM
zack77's Avatar
zack77
Space Cowboy
Me too, on the passengers side :angry: and all the carpet in back gets soaked and starts to get that wet dog smell, well maybe not that bad.
Old Mar 22, 2004 | 07:46 PM
crxsiperf's Avatar
crxsiperf
Im starting to think tha rear hatchg isn't the cilprit here , does anyone know how/where the sunroof drains are , and could it be leaking through the rear squirter for the hatch , i wanna get a rough idea before i start ripping shit apart, it seems like its leaking onto the plastic and decencing onto where the rear hatch support bolts up , and when i get in the car and start moving around it starts pouring out .
Old Mar 22, 2004 | 08:00 PM
shawn_crx8891
the sunroof has a tube on each corner of the assembly. the tubes run down the pillars (if you look behind the rear wheel wells inside the car, you'll see it). i have the same problem with the water gettin into the plastic and leaking out of the hatch strut bolt location. i haven't had a chance to take the plastic off yet, so i'll let you know if i find the leak. hope this helped.
Old Mar 23, 2004 | 10:27 PM
Pharmacist's Avatar
Pharmacist
Street Corner
also watch out for the little rubber grommet i guess you can call it that takes the wires for the back winshield defroster and supposedly doesnt let water in... if thats not completly snug into place water can get in though the hole and it actually leaks right over the driver side speaker
Old Mar 24, 2004 | 05:03 AM
BullFrogger's Avatar
BullFrogger
Banned
its the rubber liners on the roof. take em off. silicone the whole strip. then buy new gaskets. fixed.
Old Apr 18, 2004 | 07:41 PM
LSVTECKING's Avatar
LSVTECKING
rebuilding
Check where your hatch bolts to the body. Mine was rusted sorta badly and once I had the body fixed the water stopped coming in. This might be your problem
Old Apr 20, 2004 | 08:26 PM
Java Jack's Avatar
Java Jack
Default Had the same problem
I had the same problem here with an 89 CRX. Hatch was leaking right onto my passenger rear speaker.
I ended up replacing the hatch because my back window shattered (unrelated incident). When I put the new hatch on, I used silicone sealant on the bolts to the body and it stopped all the leaking.
Try pulling hatch off and using a rubber sealant on the 4 mounting bolts and hinge. It might help resolve the problem.
Good luck
Java
lethalpenguin
Do It Yourself
4
Jan 3, 2007 11:04 PM
alnen
6
Jun 15, 2003 11:36 PM
blkdragteg63
Engine Swaps, Tech & Tuning
15
Dec 23, 2002 06:41 PM
Awax223
CRX & Pre 92 Civic
3
Sep 18, 2002 04:44 PM
99IntegraGS
12
Jul 9, 2002 06:57 PM
