Crx B16A throttle problem HELP!!!!!!!!
Old Mar 2, 2004 | 03:57 PM
crxvtecred's Avatar
crxvtecred
Default Crx B16A throttle problem HELP!!!!!!!!
When I take long trips in my CRX w/ B16A and I am at steady throttle the car will act like it stops firing so i push the pedal to the floor and it kicks in again. It will do this until I turn the car off and then if I start it back up it works fine. No codes are showing. Also, the exhaust smells real rich and has moisture in the exhaust pipe. HELP!!!!!!!!!!!
Old Mar 2, 2004 | 08:54 PM
A_PHOBIA's Avatar
A_PHOBIA
the moisture is just condensation,prolly has nothing to do with your problem.
Old Mar 3, 2004 | 06:04 AM
cashizslick's Avatar
cashizslick
Make sure your throttle cable doesnt have any play in it . . . .
there is a lot of stuff that this could be from. Maybe there is a problem with your fuel systems ie. dirty/clogged injectors?
Old Mar 3, 2004 | 07:50 AM
crxvtecred's Avatar
crxvtecred
I have already changed my injectors, plugs, and (fuel filter 8 months ago). My throttle cable has no play. My car also guzzles gas. Maybe fuel regulator will help?
Old Mar 4, 2004 | 08:27 PM
Keebler's Avatar
Keebler
You Dream It, We Live It.
have u checked all the cables and relays to the throttle? there might be a small problem there, cuz sometimes u can have a small crack in the cable shroud and it might be causin the actual cable itself to slip thru the shroud and malfunction
Old Mar 6, 2004 | 08:16 AM
crxvtecred's Avatar
crxvtecred
I will check!
CRXtreme20
CRX & Pre 92 Civic
10
Mar 29, 2003 01:03 AM
rynxprs
CRX & Pre 92 Civic
3
Aug 8, 2002 07:19 PM
sir_crx
Jul 26, 2002 08:08 PM
