as long as im swapping engines, what else should i do?
like the title says, ill be swapping the engine from one of my 85 crx si's to the other in probably 3 weeks. what are some things that i ought to do while its out? im planning on checking the clutch, changing the timing belt, and swapping the fuel rail as the one on that engine is leaking. what else should i do?
Rotorphile.
Waterpump, fuel filter, check the CV boots, valve cover gasket, air filter, of course the engine and trans oil and coolant... that's all I can think of at the moment.
to the new engine going in: i'd do the headgasket, water pump, alt & timing belt and pretensioner, ac belt if you are keeping it, plugs & wires, and depending on the mileage of the engine maybe new piston rings, and crank bushings (i normally would rebuild the engine if it had over 100k miles on it)
VN-TEC
12
10-28-2003 08:41 PM
jaje
News & Rumors Archives
33
12-30-2002 08:18 PM
jaje
07-11-2002 08:01 AM
