fuel cutoff problem?
Old Feb 5, 2004 | 10:54 AM
menappi's Avatar
menappi
Default fuel cutoff problem?
alright so when i was driving, my car lost all power and began to slow down, even when i was on the gas (like i was runnign out of gas) but know how far i can go and i should have had at least 30 more miles before i had to refill. so i pull over, turn my car off, start it back and its fine =\. i went to get some gas and it didnt do it again. it happened once before, and lef tme stranded, but only started after after i installed a fuel cutoff switch, only i didnt install the switch, and left the wires twisted and wrapped in tape. could that cause my problemm?
Old Feb 5, 2004 | 12:27 PM
kd5dbl's Avatar
kd5dbl
Originally Posted by menappi
... could that cause my problemm?
could is a pretty big word, and yes, it could.
Twisting and wrapping in tape isn't a very good electrical connection. So I would check this first. If you want to eliminate this as the cause, make a better electrical connection (solder, wire nutt, or at least some quality crimp connectors) and see what happens.
Old Feb 6, 2004 | 10:42 AM
speedshifter101's Avatar
speedshifter101
I have a 91 hb with a 90 ls swap and mine does the same thing. it throughs a engine code 9 and i think that is why it isn't runnin right.
Old Feb 6, 2004 | 12:19 PM
kd5dbl's Avatar
kd5dbl
Code 9 on an Si ECU indicates a fault on cylinder position sensor. And yes, that would make it run poorly.
Old Feb 7, 2004 | 02:42 PM
menappi's Avatar
menappi
yeah i have a b18a1 on my car too, and i noticed something weird..or what seemed to be weird on my engine. when i look at it from the front, right next to the distributor, on the head towards the front of the car, there is a hole which has bolts that looks like something was supposed to be bolted on there. im thinking either the crank angle sensor or cps?? but instead there is a black rubber cap coverin it. im thinkin it all depends on if my distrbutor has that sensor in it...but any help? its obd0 too.
Old Feb 8, 2004 | 05:16 AM
kd5dbl's Avatar
kd5dbl
Dunno about the b18, but the CPS on a 1.6L is connected next to the distributor (towards the firewall). I would think that if your's didn't have one at all it wouldn't really run well at all and would be blinking a code.
Old Feb 8, 2004 | 12:57 PM
speedshifter101
I have the pr4 ecu and i heard from a friend it might be my distributor that is throwin the code 9.
jordan88
92+ Civic/EL & Del Sol
2
Jul 14, 2003 09:44 AM
88mphDotOrg
2
Jul 10, 2003 11:38 AM
undrgrndhaqer
Engine Swaps, Tech & Tuning
10
May 14, 2003 07:14 PM
wushu_civic
3
Apr 20, 2003 05:33 PM
jaje
News & Rumors Archives
12
Dec 26, 2002 08:41 PM
